I’m thinking of updating my Uniti 1 with the latest software that came out earlier this year and wondered if anyone had tried it on their classic Uniti product?
If so was it a worthwhile update, my Uniti 1 has the upgraded board used in the later Uniti 2 so if anyone who has updated these particular units that would be especially helpful.
I upgraded my Uniti2 to the new software, for the multi room I think? Or was it other stuff? Anyway, it was all straight forward and works fine.
The main point of this update was to fix issues with some HLS feeds, with Tidal and some small bugs. I don’t recall seeing anyone report it as sounding any different to the previous firmware. You can always roll back if you want anyway.
Best
I asked Naim re last update for Uniti 1 and naim said yes. So I did. Not sure if sounded better as use mine as source for Naim Nait 2. However it did not break it and solved the old streamer update message I used to get.
