I am weighing up these two options. As a bit of background, I bought a newTibo Bond 3 (similar to the small Yamaha streamers) circa 4 months ago to dip my toe into streaming. When added to the main system and through the Tibo’s analogue output, I was was quite impressed, especially for the £40 (RRP circa £80) I paid. I am signed up to Spotify Premium Duo which works well.
The Tibo App works well and we have since bought the Bond Mini and the recently discontinued Vogue 3 portable speaker (really good for £45 end of line). My experiences have suggested that streaming would work for us, so I am wondering about getting a proper set up for the main system.
Unfortunately, I cannot currently justify an ND5 XS2 so a legacy streamer such as the ND5 XS, a UnitiQute or a 172 would be the only real options from Naim. They all seem to be priced from £500 to £1,000 depending on recent service/screen replacement/bravery of the seller. I don’t need the amplification of the Qute - I would just use the preamp out set as close as possible to line level as possible. The unit would only be used to stream from the web and probably, at least to start with, by WiFi only.
What I would like to know is how a legacy Naim streamer (presumably updated to be able to play Spotify premium) would compare with something like the Tibo (streamer) feeding a good DAC, such as a Chord Mojo/Rega DAC/Arcam D33 etc. The Tibo Bond 3 on its own sounds acceptable but not as good as my CDSI. However, I plugged it into my AVA Meastro 50 digital amp via Toslink in the office system and it really did improve it proving it has better streaming capability than its internal DAC can demonstrate. I could buy a new Tibo and Chord Mojo for less than £500 - would this be just as effective as something like the ND5 XS for what I plan to use it for?
Any thoughts would be appreciated.
