Lights gone off 252
Not only have I lost the display on my NDS (paid £6,500 for it) now my 252 has had the illumination go apart from Naim logo ?
Is this a sign that the 252 needs a service? Do pre amps need a service
Still plays fine
Forgive me for asking the obvious, but you’re sure you’ve not pressed ‘Display’ on the remote?
My understanding, from what I’ve read on the Forum, is that servicing at the prescribed intervals is more important for power amps, less critical for pre’s. How old is your 252?
I don’t know if your remote is the same as mine, had the same prob. on your remote press the pre. button and the disp. button, reset mine.
