Hi
I have recently changed my internet provider, my password has an @ in it and I cannot work out where to find @ on my streamer. Any help would be much appreciated.
Donald
WiFi passwords are normally created using numbers and letters A to F only. Check the default WiFi password, it is usually on a sticker on the router itself.
If the password does contain symbols then you will need to change it.
You should be able to go into the new router and set the network name and password to be identical to your previous one. Doing this means that everything will automatically connect and there is no need to log in again.
