Hi all,
Please can someone help.
How do you link Naim 333 and Naim 222 together so you can get the same tune playing inside as well as outside in the garden ?
Thank you in advance
Hi all,
Using the remote press the button with 4 squares on it, this takes you to a screen called Multiroom and there you can select the devices you want to share to. Both have to be on the same network and you can share either way between the 333 and 222.
Thank you so much for replying, that’s very kind.
I’ll give this a go tomorrow, and I’ll let you know if that works.
