Hi, I have a Nova and would like to know the best way to link wireless speakers as a second option. Main speakers are wired. I am sure someone has the answer - thanks
Hi, there is no wireless output as such on any Naim streamer, other than to another Naim streamer using the multiroom function. So you could add, say, a Muso and it would play in sync with the Nova, or independently of it.
Thanks ChrisSU , yeah I thought that might be the only option, maybe an option to get a device to connect to headphones socket.
