Linn Klimax DSM in my naim system
The Naims and Linn Klimax have very different architectures. The Naims are more traditional (but extremely well-executed) HiFi-boxes with digital add-ons.
The Linn Klimax more like a Linux-based consumer appliance with a very good (and short) audio-path. This makes it easy for Linn to integrate featuree like SO. And both pitch-stability and rythmic drive is excellent with Organik on top of the fine detailed, grain-fee organic sound signature.
So they both have the same musical goals. But are very different products.
Just a question, did you go directly to your 500 from your DSMā€™s or via the pre-amp? I know this can be done but whenever Iā€™ve tried to circumvent the pre-amp, especially a Naim, results have tended to be a bit cold, lifeless and two dimensional. The Naim pre-amp is considered to be a critical part to the whole balance of the system and with out it results can be a bit questionable.
In my case the Klimax DSM and naim 250dr sound better than the Linn Majik amplifier I auditioned it with at the dealer.
In the various reviews of the Klimax it sounds very good with many different brands of amplifiers , with a preamp adding little to the presentation via streaming. If you are just streaming it seems a preamp is not really necessary.
But I have not heard a Klimax into a 500 dr so that may be different
@james_n uses 2 x 350s into NG KDSM.
Maybe NC gear is designed for this now with balanced cabling.
So interesting proposition Linn KDSM into 500DR. If you have LP12 the Urika 2 can be used as phono stage direct into KDSM. But you would need Radikal for Linn as well.
NC has open up the market for pairing with the XLR , making naim more user friendly and more exciting exploring other makes combi w great resultsā€¦ in actual fact , naim pairs very well w other makes w even with the OCs. I had done that w the OCs before going into NCs
Itā€™s a great move by naim.
Personal thought: Thereā€™s not really much point in attempting to describe what organik (and its package) sounds likeā€¦all these descriptions are subjective and difficult to put into words. If you are interested, you need to listen to a burnt in example. It sounds totally different, but thatā€™s my opinion. I have huge smiles when listening. Itā€™not like a development, itā€™s a revolution.
Agree totally. My system sounds sublime. Itā€™s not been cheap getting there, but a lot less than buying it all new! I have no desire to change anything (except a cartridge upgrade perhaps on the TT) - and it just sounds ā€œwow, thatā€™s lovelyā€ every time I listen to it.
I tried both. My main goal was to eliminate boxes, cabling, etc. and just simplify things. I connected it directly to the 500 DR with the cabling from my dealer allowing the connection to the Klimax. It sounded good but just not as good. I would say a bit more transparency on some songs. Just felt like the music sat behind the speakers if that makes sense. With the 552 it was probably a bit better. I did this same thing again with a Selekt DSM with dual organik and I actually thought it was better than the Klimax but still not enough to push me over. So I stuck with my Naim gear once again. I always go back to Naim. :slight_smile:
I wondered that as well @Dan_M with the NC stuff. I just feel like the 500DR is meant to be with a 552. I donā€™t have a way to demo a NC amp with a Klimax DSM though.
+1 :slight_smile:
Hi @IDAK, itā€™s interesting that you had to take time to adjust to that more open sound signature. For me, that was precisely what drew me to Linn/Organik, but then I listen to a lot of classical, plus some jazz and traditional acoustic stuff rather than much heavy rock, for example. Also my active ATC speakers have quite a weighty presentation and, to my ears, balance nicely with the Linn.
I find the NC gear (or at least the 200 series, Iā€™ve heard) has moved a bit in the same direction which may explain why some OC owners find it less congenial. It wasnā€™t available when I changed my system. Had it been, I might possibly have made a different choice.
Roger
I am not particularly worried about box count but I havenā€™t been enjoying my ND555 for some time and Linn appear to have a trade in offer for Klimax DSM, which could present a low cost opportunity to replace the ND.
If I understand correctly, I could run a Klimax DSM directly into NAP500 and potentially do away with the 552, but removing the 552 is probably a step backwards and therefore better to leave it in?
Is it felt the Klimax DSM might be a viable alternative/contender to ND555/2xPS, through 500 series amplificationā€¦Note, not necessarily an ā€œupgradeā€ but at least a viable alternative if the outlay was minimal?
Just beware that Linn Switch mode
power supplyā€™s can drag down the performance of the Naim amplifiers.
Wouldnā€™t that possibility be mitigated with shielded interconnects and in the worst case, by putting the Linn on a separate power supply?
@Elfer My NAP250dr has never sounded better with the KlimaxDSM as the preamp. However if you were thinking of doing away with the 552 it would best to perhaps have a Klimax home trial for a couple of weeks , with and without the 552. Given the Klimax cost the dealer should be agreeable with that idea.
Need to put the Linn on a separate spur.
Just curious, which switch mode are you referring to? AFIK, only the Linn Solo and Twin amps have switch mode technology.
Thats a handy piece of advice, and makes sense given the Utopik SMPS.
Not an effect Iā€™ve noticed at all with my 332/300/250, but then I do use shielded mains cables (Vertere Redline).
Good to know too. It would be an easy experiment as I have both dedicated and household spurs next to each each other, and a shielded power block from Sean Jacobs.
