Due to NDX2 needing some loving care back at HQ, I’ve got the Bluesound Node in fixed output mode > optic link > DAC-V1 > Nac 202. (Sounds good by the way once the input on the NAC, which hadn’t been used before, had warmed up!)
The problem is that although I’ve found how to set the DAC-V1 to a set output in the settings, as soon as I use the remote control for the NAC202, it changes the volume/output level on the DAC! In other words it doubles the effect.
Anybody know how to either lock the DAC-V1 output or disable the remote for it? I suspect I’m stuck with this inconvenience…
If you’ve set fixed output properly -which I suspect you haven’t - the issue will go away. You need to confirm the selection of fixed output - see below.
I use a DACV1 for headphone use when I purchased it my dealer set it so that the remote codes don’t clash between my 252 and V1 might pay to contact Naim.
