Looking for a Naim Streamer with Dac
Looking to get a Naim streamer with Dac. Only using for 1 system so dont really care about multi room and right now mainly using with Bluetooth as cant connect to modem as it is too far away
Price is not too much of a concern
The ND555 is therefore your answer.
No, the concern is you can only use it with Bluetooth.
100% Nigel, Bluetooth on ND555 is like using a DBS for the school run.
Clancy, you really need to look into getting web and local streaming first, then you can get the best out of Naim streamers. And don’t worry about a Naim streamer with a DAC, they all have one.
