As a result of room redecorating and moving the equipment around my speaker cable is about 1m short on one side.
My cables at 5m superlumina. It’s far too expensive to trade in and buy a longer pair. Any solutions suggested for adding about a metre of something else. Current termination is 4mm plugs. Speakers are Fact 12, amp is NAP300 DR.
The only idea I have so far is add about a metre of another cable type via 4mm socket. No idea what though. I don’t think Naim do short extension pieces.
Unfortunately, short of shrinking the room that’s not really an option! The speakers and fraim are limited in where they can go.
Not ideal, but we have to have some compromises.
By coincidence this morning, I was reading about the Audio T visit to the naim factory in which the construction of SuperLumina cable was mentioned.
There are resistors fitted to the cables and these are adjusted to suit the length of the cable, so any change to the size will impact on how they perform any therefore potentially not be optimum.
To quote the Blog → It was explained to me that this resistor differs depending on the length of the cable 3m, 5m, 7m,
So working on the theory that extending Super Lumina is not optimal for the reasons given eg wrong resistor in cable would you consider demoing different cables of the correct length. Yes aware you probably did this already to arrive at Super Lumina but if the room has been moved around then another cable may suit or possibly be even better in the new environment. If there is another suitable cable it may be cheaper and you might even come out positive cash wise if you sell on your Super Lumina. I’m sure there are plenty of folk here who might be willing to take your Super Lumina off your hands.
I’m not sure that buying a 1 metre extension is a great idea, and I very much doubt that Naim would sell you an unterminated length. The large number of silver plated strands of varying gauge wouldn’t be easy to re-terminate.
If you really want to do this, you’ll likely have to use a different cable, maybe NACA5. I doubt very much that having the ‘wrong’ resistor on the existing cable would be a problem.
Maybe worth doing this as a short term fix, and contacting some Naim dealers and searching eBay in case a used 6m pair come up, then you could sell yours and possibly avoid too much cost.
Yes, might try making something else up with some other cable first. I might only need to extend half meter in the end, won’t know until all is built and in place. Probably the best approach and I can compare with and without the extension.
In the meantime I could look for a 6m pair but there’s not a lot about even in more conventional lengths.
That’s a good idea, especially as you are handy with a soldering iron. Mogami 3103 speaker cable could be an option.
High quality, professional speaker cable, at unbelievable low price.
