That suggests your speakers will be very close to the side walls and you’ll be sitting hard against the rear wall?
As in you have to double back? You can’t exit under the unit?
I think you might need to post a floorplan sketch… ![]()
Can the Fraim move right up to the media thing, behind a speaker, saving you 1m and at the same time both partially hiding tge kit your wife has to tolerate, and making it almost part of the media dentre - and after all audio is just as much a medium as TV? (When you said media wall I briefly thought printed posters, album covers, newspaper cuttings etc pasted all over the wall, not a TV and a decorative fire.) And said she tolerates rather large speakers, but those Fact 12s are very small when viewed from in front, while the media Centre will be a monstrosity in comparative terms!
I would be inclined to sell my SL cables and replace with NACA5 of the correct length
Each to his own
My point was that if the media centre is her choice, then the flexibility of placement of rack and speakers, overall smaller and less dominant, could be yours
Family life doesn’t work like that, but the slatted wall TV mount and fire is more my choice!
It just happens that the speaker cable will reach the far end of the unit but not allow the speaker to come out enough from the back wall.
At the end of the day we’ll sort it but I have now some suggested alternative cable types.
Wow I might need this!
I would second the suggestion that NACA5 is probably the best option to try, and a dealer may be able to loan you some to try.
Another possible option for your shortlist: Vertere cables have a lot in common with Super Lumina. Not cheap, but they used to make one called Pulse X Mini which I believe was made by the same manufacturer as SL, although not identical.
Added to the list, thanks
Adding a metre either side with another " reputable" cable is not ideal (search for 4mm banana female plugs ) but its not going to break the system or ruin the sound . You will have a slight dilution of the SLs characteristics. I would recommend VD tour grade or mogami as both are characterless. Giving you the chance to sort your next moves without pressure .
With the aim of avoiding a cobbled together interim solution…
May I suggest (eg, because they’re (relatively) flexible and easy to resell) an 8m pair of KS-1 while you find the best position for the various parts of the system, and only then decide whether you can’t live without SL?
