Is anyone else finding the Loop icon is no longer persistent in the App…?
For years, I’ve pretty much always had the Loop icon selected, as I’ve never minded if a selected album begins to repeat again before I select something else….I can’t remember ever having to turn it back on, regardless of whether I’ve flicked to other sources i.e iRadio in the meantime…Normally when I’d go back to either UPnP or Qobuz it would still be there – TBH, I used to forget about it even.
I’ve just happened to notice the last week or two that it doesn’t always seem to stick now – it’s certainly not consistent, i.e if and when you change source, it just seems to be happening randomly….
Presuming this has come about post the recent App update and may be a bug…? If it was a deliberate UI change, I’d presume it would be consistent when it turned itself off i.e when stopping play or changing source…?
SC
