Hi Keith,
I’m glad to hear that things seem to be progressing OK for you.
As far as technicalities are concerned, @davidhendon is most definitely the person for you. I may have been lucky, but the default program my Audiologist set up for me seemed to work from the off & has not required any adjustment. My first annual review was in February this year & my hearing had not deteriorated any further so the automatic default remains unaltered. My view is ‘if it ain’t broke, don’t fix it’ & has meant, so far, that I have felt no need to find out anything about the technical side of things. As far as I am concerned, long may that continue.
However, the Phonak (Android app in my case) was very poor in January 2021 (when I purchased my aids) so I didn’t bother with it until about Christmas time or early New Year, when it was upgraded & worked pretty much as it was supposed to.
I therefore fiddled with the setting to see what it could do & how adjusted settings compared with the default program. Two things emerged for me. Firstly, the settings did make a noticeably difference. Secondly, none of them improved the quality of sound over my default settings so those are the ones I have largely stuck with. I do use the default music setting as it is supposed to reduce background noise levels. I can’t say it sounds any different to the default Auto setting as I am nearly always listening to music in a silent room (bar the music of course!).
You should discus you early findings with your Audiologist but also be prepared to give your ears/brain time to adjust to what you are now hearing. If you still feel the mids are a bit recessed & the extreme treble also, then I would suggest, initially, you copy the Music program on the app. Go into it, don’t adjust anything & simply hit the save as button & give it a unique name. Go into the program you have saved & then play around with the settings to your hearts content & try to dial in the settings that suit you. You may be able to fine tune the mids & highs to just how you want them.
If you do create a program exactly to your liking give it a few weeks to make sure you really do like it because it is good & not just different from the auto or standard music programs. I made a musis program that I felt was better than the standard ones. However, after a few days I realised the treble, initially sounding very impressive, was in fact too bright, hard & quite fatiguing. Going back to the standard programs was so much better. If you do find settings that, over the long term, sound better to you then you can return to your Audiologist & ask them to make the necessary changes to your automatic default program.
Once you have had the aids for a while, & the novelty has worn off so that you don’t really notice them, try listening to music, take out the ear pieces whilst listening & ‘see’ what difference you notice. I was surprised just how dull the music without aids actually sounded.
A couple of things to end with. I haven’t suffered from an sibilance & if you are I would have thought that this can be programed out. I can’t recall if I actually said my hearing sounded like when I was younger. I obviously have no idea what it sounded like 40/50 years ago. Whatever I said I meant that music today sounds much the same to me as it did 3/4 years ago which was probably not far from what I remember it sounding back in the 1970s/80’s. Hopefully you will get my meaning.
Hope things go well for you & that you will give us further reports in the weeks/months ahead as to how things are going.
