Lost display on nova
I lost display on the nova, nothing is show but it work fine I control with the app and roon.
I install a powerline cable yesterday. But not problem with display.
I also try primephonic , via chrome cast. It seem not so easy to close down,
No stop button in primephonic or Naim .only pause .
If you remove the power from the Nova, then connect the power again the display should come back.
Regarding Chromecast, normally you have just pause and play. You don’t need stop. Nothing happens after you pause it unless you tap play again. So pause is stop effectively.
Best
Thanks. Everything works fine.
