I would totally recommend the sourcing of a Headline….paired with a HC.
Bought mine a few years ago after auditioning headlamps from Sennheiser, Beyerdynamic, and a few other and totally preferred the Naim stuff…
I use them with my HD 820 and Beyer T5 3……
It appears that I have the same incompatibility issue.
Also the Chord cable was wired up wrong.
The dealer has taken the Trilogy back and lent me a Benchmark in the meantime.
I had this with a cable I had ordered. Label and packaging stated is was output. But it was in fact a standard input cable.
The manufacturer just sent the correct cable and I sent the incorrect cable back.
It would be worth checking the orientation of the cable.
DG…
The cable is going back.
I’ve decided to go straight out of the NDX2 to headphone amp with RCA’s
I picked up a mint Headline with a NAPSC a couple of years ago from a well known auction site.
They do come up now and again, so it is worth watching out for one.
DG…
This seems to be a common issue. Either people just ‘guess’ that any DIN to Phono cable will ‘work’ - which is absolutely not the case (unless its a DIN to 4 Phono, which will always work - if you select the correct pair of Phonos). Or the cable is plan wrong, as on this occasion.
Hmmm…
