I had set up the Core with my NAS as its music store. I had just ripped a CD and then selected an album to play. Nothing happened.
So I reset the app and tried again but nothing happened. Then I did a power restart of the Core and after that it showed no network drives. Did another two power restarts and then a factory reset and still no connection to the network drive.
It was all working fine last evening.
What else should I do? Or does it need to go back for repair?
I suggest turn it all off again, restart your router, let it fully restart then turn your Core and NAS on again.
If the Core can’t see any drives that us usually a networking issue. And restarting the router is usually part of the answer.
Best
