Hi all,
looking for some help please, I’ve dug out a pair of Linn Sara speakers from the loft and I’m pretty sure we threw the cables out a few years ago during our 10 yearly loft cleansing extravaganza…
As some of you will know, they have an XLR connector to the rear of the speakers, I don’t have any, but just want to test them before letting them go. Google has not thrown much up in the way of this type of connector. Is there a way of connecting them to an amp without genuine Linn cables?
it’s that simple HH? wondered if there was any Linn wizardry going on. I better get on the web and find some female XLR connectors and some instructions…
Thanks for taking the time HH.
That’s assuming they are the standard passive version with internal crossovers. There should be a diagram on the back showing which pin is positive and which negative.
So it’s just a matter of getting a couple of female connectors and wiring pins 2 and 3. I have no idea what that description of pin 1 means, but it looks like it’s a factory testing thing that you can ignore.
Thanks Peder, first I want to confirm they work. It’s been a while, like 20 years I think. you never know I might keep them and get some pucka XLR connectors. Cheers
A
After some pretty dire soldering I’ve got the Saras’ up and running, TBH I’m quite shocked by just how good they are, the depth of bass and open feel to them. Has anyone had these in the past? did they rate well back in the day?
A
Hi Alec,
I owned a pair in the mid 1980s, together with a Linn LP12, Ittok, Karma & a Naim 32.5/Hicap/250.
They were quite something and revealed their true grooveliciousness when powered by a pair of the then new NAP135 power amps.
