Hi! Have a MacBook Pro that is connected to a Naim DAC by a USB cable (usb C on the mac, adapter to USB B then USB A at the DAC). Before I updated the operating system there was a dropdown box where I could select output to the Naim DAC instead of the built-in speakers. That option has disappeared. Solutions? Thanks! P.S. Thank you for your help with my last question, about the transformer hum.
Okay!!! Relax!!! Donβt panic!!! I fixed it!!! Thanks!!!
How did you fix it?
I am about to change my MacBook for an newer model and I, plus other users might face a similar issue!
Presumably click the sound icon and then output
