It has been quite interesting watching your journey on this! I discovered this starting with Hugo1 particularly feeding direct to a power amp, then fully brought out (initially with a big Wow!) with Dave and a better power amp. I never tried through a Naim amp, so I don’t know how limiting that might be in comparison, likewise I haven’t heard through Etude, so have no idea how much better that may sound, but it is certainly natural sounding and very engaging how it is, so much so that nothing drives me to try M-Scaler, or to try inserting my old Gustard USB-SPDIF converter/isolator between renderer and Dave to see if it makes any difference…
I did use it briefly when I bought my Qutest, but having a £5k digital transport made me a bit queasy once I heard what Chord does. I can understand why others would choose to keep the NDX2, but I used the money for an MScaler and am very happy I did. For me the NDX2 is a great product…as a standalone.
I am really interested in the relative merits of different digital transports. I know @Simon-in-Suffolk has talked about this, and the quality of the NDX2 spdif out, but I do wonder how much difference a DCS Network Bridge is to, say, a Bluesound Node when used with an external DAC like Chord. Certainly I didn’t hear a difference when I changed from the NDX2 to the Mind 2 when used with a Qutest.
Thanks would be great would be interested in your thoughts on the ST60. Particularly the sound from digital (optical), usability of airplay (I connect my Apple TV so volume control), Chromecast (does it turn on and switch to the Chromecast input when I ask my Google Home to ‘play BBC radio on Arcam speaker’) and Qobuz integration.
Looked up Benoit Mandelbrot. Fascinating. Not heard of him before I’m ashamed to say.
You make some good points, but I just don’t like to see so many people moving from Naim sources to other manufacturers. From reading some of the other threads, a lot of members are doing that, and there’s most likely a lot of others that aren’t on this forum doing the same thing.
As long as Naim continue to ignore that piece of the market, they will continue to lose market share on those items, and the worst part is that those people follow up that purchase with they purchase of a Dac from another manufacturer, and then some other piece of kit in the chain.
It would be very easy for them to make a streamer without a DAC, even if in there engineering minds it’s a bit of a lost leader.
I’m with @david1111 here.
Server/ streamers (like Innuos and my own Audiostore), stand alone streamers, standalone DACs and streaming preamps seem to be the direction of travel. If Naim “die-hards” like those posting on this forum are moving away from the brand to avail themselves of someone else’s front end kit then surely their amps will soon follow.
Apologies to the OP for thread drift!
Some have already taken another path. From Naim , to Naim with Chord dac and finally all Chord.
2 members have now a chord etude amp, which matches better for them with chord volume control.
In respect of people on this forum I get the impression that more often it is the other way round: they discover that there are DACs that present the music in a way that is better to their ears/expectations, and then the redundancy of having a full-blown streamer with inbuilt DAC but using only the front end drives them to find alternatives. If Naim want to address this, then Offering a range with separate streaming renderer and DAC might help, while considering what it is about other DACs that draws people to them away from Naim. I suspect, but don’t know, that hanging on to an old DAC chip and simply(?!) trying to wring the most out of it, rather than alternative approaches, has ultimately limited them.
And In response to your observation about one purchase leading to more from the same manufacturer, that may hold true if the first experience with the first item is particularly positive (seemingly common with DACs), however of course there are many people who do not see automatic benefit in being wedded to a single manufacturer, for whom mixing and matching on the basis of best, or best value, is natural.
There are still a lot of people who prefer the Naim presentation. Hopefully all tastes are possible.
I would be very happy if Naim could produce a streamer without dac. I would not have to sell my Nds for so ridiculous money and buy an Nd555.
As this is a Naim forum I would hope there are still a lot of people who prefer the Naim presentation. Lots of valid opinions and options on this thread, a Naim streaming platform without a dac would be attractive but as others have pointed out without new dac development by Naim this may prove unwise.
I have always thought the Naim Core was a missed opportunity, why not a server, streamer with Roon core capability to compete with the likes of Innuos ?
The OP could try Roon and use his TV as a screen, MUCH bigger than the NDX2.
Check this post out:
I tend to lean towards a single manufacturer supply for my gear, and there are a few others that do the same, but you are correct that many do not feel tied to a brand (and shouldn’t), and probably end up with a better all-around SQ in their system because of it.
And it most likely is a good time for Naim to reassess the chips they use, and possibly some other design features of their Dacs, if other manufacturers are achieving better results for a lower cost.
It’s always money dependent of course, otherwise I’d have a $50k (CAD cost) Rossini with Clock.
I personally don’t require any better presentation than my NDS provides, even tho I do realize that this is a bit of a ‘head in the sand’ attitude. I wouldn’t promote this tack to others.
Exactly!
I did listen to the 2Go/Hugo2 a year ago via headphones acting as a roon endpoint with a Macbook acting as the roon core - this was on Chord’s stand at the Bristol show - as it was on my list as a potential choice for a streaming source. It’s launch has been imperfect, but yes it should be usable to store and play up to 4Tb of music files once 2Tb cards become available.
I have only seen one real comparison of the 2Go, and that was a brief statement to suggest it is on the same level as an Allo DigOne. All other reviews I have seen have been of the 2Go/H2 solo. The rollout of the 2Yu docking point (for connecting the 2Go to other DACs) has been on hold, maybe there will be a release soon.
The 2Go can also be a roon endpoint, although the roon core/server cannot read the files stored on the 2go’s microSD cards.
Ta WeekendWarrior that would be a big screen.
I have sort have gone the other way, I have an NDX 2 with XPS DR but wanted a headphone out capability so added a Chord M Scaler and Hugo TT2 to my system, this to avoid being moaned at by the family for playing my music via the loudspeakers, I could only really do that when I was in the house alone. My system comprises of an Innuos Zen Mini Mk3 with LPSU, used as a Roon Core device which I feed into the Hugo TT2 via USB, this can feed the Naim NAC 252 as well as the NDX 2. Both systems sounded great but as with this hobby I wanted more (I need to stop this urge) so started to look at the Innuos Zenith as a replacement my Zen Mini, trouble is I have gone too far and decided to go with an Innuos Statement (Doh!!) and trade in the NDX 2 / XPS DR. I felt that I did not need to have 2 streamers in my system, I didn’t want to upgrade to the ND555, so with a degree of regret decided to loose some of my Naim kit, I just hope this was the right decision.
OP here.
Started an interesting discussion, seems a lot of love for the Chord TT2 over a bare NDX2. But equally a lot of switching back and forth. Investing in the dac seems to bring more benefit over the streaming element. I really like the TT2 and would be reluctant to part with it, so going to keep it and look to improve the streamer.
I need WiFi, Airplay(2) and would really like Chromecast and a screen. Plus got to look good as will be on display (a criticism of the Node 2i - wife thinks it looks cheap alongside the rest). Current candidates are ND5xs2 (but lacks screen), Auralic Aries G1 (no Chromecast), Arcam ST60 (not sure about OS, build or sound) or perhaps Primare SC15 (seems well specced, looks nice and well priced). Any THOUGHTS/EXPERIENCE on these as STREAMERS TO EXTERNAL DAC?
Hi Blondy,
As I am sure you would expect there is no straightforward answer. Not everyone prefers the TT2 to the Qutest, and the Qutest gets a nice lift if powered by an SBooster + Ultra II; which is what I use.
I think the nDAC is an excellent piece of kit and used one when they first came out for a number of years.
Ultimately you will need to do the legwork and listen to them in your system.
M
A complementary view to @Simon-in-Suffolk regarding the NDX-internal DAC vs Chord DAC - albeit on a lower level system than Simon’s. I have had the XPS-DR here for 24 hours, it is an ex-demo and appears to be working well by now with my NDX2 / 282 / SuperCap2/ 250DR .
Taking Simon’s ‘house-party’ analogy - I have been playing the RP Rock Mix today - two classic rock tracks which I know well from my younger years - ‘Black Sabbath - Paranoid’ and ‘ZZ-Top - Sharp Dressed Man’ - these both are high-energy tracks which have a simple driving riff, in other words intrinisic ‘PRaT’ - the NDX2 really does deliver the goods with these and other rock tracks.
For more complex music be it progressive rock, jazz rock and symphonic musc then I prefer the more natural Chord Hugo 2 - and for simple female vocals/acoustic guitar e.g. Eva Cassidy, either presentation sounds good to me.
Again my ears, my room, system synergy etc.
You should also include there dCS bridge (though without screen).
Given the features u r looking for the streamer, probably NDX2 is best option compared to its competitions. IMHO it is also best value for money between the Naim ones - ND5XS, NDX2 and ND555.
I also wanted all these features and hence went for NDX2 after comparing and auditioning a few. But NDX2 is costlier by around 2 to 3 grand (in USD) from competitions. My plan is to later adding a better dac to its spdif - MSB or PS Audio TSS (not yet out) or may be Mola Mola Tambaqui.
Sourav
