Aruba InstantOn is more robust IMO and the cloud based GUI is better thought out.
I switched from Ubiquity a few years ago after getting fed up with being an unwilling beta tester.
1 x AP 22 in use at home.
Interesting. I tried the google Nest system but the setup instructions were pretty much non-existent. Didn’t realize you could do that.
EDIT: Ah, I see it’s the “Pro” system, haven’t come across that yet.
I did, just now. The TPLink didn’t want to play nicely with the EE device and I lost internet connection over the whole network.
Never mind. You can’t expect too much of an ISP-supplied box that, to be fair, does very well at what it was intended for .
Factory reset of the TP and I’m back to where I started, which is fine for now while I research what hardware will do the whole job for me.
Thanks HH, this looks well worth exploring further -though I suspect I need something between the 4G unit and the rest of the network.
I’m confused as to why you are using wireless rather than hard wiring your audio components.
