I have on order a pre-loved Super Lumina Interconnect, but it does not come with an original manual. I’ve looked online, and the best I can find is the one-page picture below. Does anyone know where I can get the PDF of the manual from?
Interconnects are Simple things. You are to simply install them correctly, give them time to bed in and then forget.
What other operational instructions are needed ??
absolutely - it’s just that I have other pdf for my other gear - I’d like to complete the collection
Not so with the Hi-Line!
Maybe call Naim Support and ask for a copy.
That might be an option, but didn’t like to disturb them from their usual work, especially as it’s pre-loved.
That definitely requires instructions, for repair return anytime you leave one end or the other of it downwind of a fart that shatters the rings.
‘If you have any questions or concerns about Super Lumina cable applications or installation, please contact your local Naim retailer, or Naim directly, through naimaudio.com or
via: info@naimaudio.com’
From the bottom of the sheet you posted…
