Mark Grant speaker cable any good?
Is the Mark Grant Van Damme 6mm speaker cable any good? It is 0.10mm conductors and 7 way plait. Resistance 3.30Ohm
Is this cable better than my current Linn K20?
I need 2 x 11m pair and trying to keep the cost at no more than £15 per metre.
Getting new speakers soon (ATC Scm40)
Not about the speaker cable specifically but I can say that the power block I got was extremely well made to my specifications.
I doubt it’s any better or at least better that’s worth the money.
But if you need a different longer length (11m) then that’s another question.
There is no specifications shown in Mark Grant website, the important spec is inductance, Naim amps require a minimum 3.5uH per channel.
So find out what the MG Van Damme cables inductance is.
Looking at the spaced conductors I suspect it’s around 0.8 to 1uH/m, so so 11m will be around 10uH and OK for your amp.
