Hi All,
What is the max capacity of USB that can be used with NDS according to your experience ?
Any posts welcomed. Thx.
Hi All,
I’ve used a usb of 256g and it works fine
Wasn’t aware there was a limit? If I had bigger than the 1/4TB I would have used it…
Disk/stick has to be FAT32 so theoretically it could be up to 16 TB.
Most OS however support a max disksize of 2 TB.
