May be binning off Roon in favour of Tidal connect .. but
See you in June then…
Ha ha… you’re not kidding!!
Not doing ours for a while
Martin
I’m leaning that way too…
25 000 000 happy users, 2 unhappy. Go for it!
Same on NSC 222 here. 96khz via Tidal Connect. Firmware 5.2.1 (latest as of 27/01/2025).
On earlier firmware, attempting to play Tidal Max content resulted in High only.
I can understand it is a difficult decision, after all that has been said about this topic. I am pretty happy with my ND5XS2 running 3.10.1.
So, I had to listen to this. Added it to my Tidal collection :+1:t2:.
Yeah she’s pretty good… I picked it up from an old HiFi review a few weeks ago
Decided to take the plunge… I’m an hour in and so far I’m happy…
First impression is more detail and separation…
No harshness that I’ve seen reported elsewhere.
Roon is like Marmite: love it or hate it.
I am of the former, Roon Nucleus One, DSD512 into a Topping D90LE. That is eight times the resolution of SACD; I still haven’t figured out how extra bits are generated; the result is very desirable.
Quick update. IOS upgraded on Mac Pro and 3.10.01 installed on ND5…
Result is well, quite amazing… goes to show why keeping software up to date and synced across devices is really important.
I’m sticking with Roon for a bit while I do comparative test between it and Tidal Connect, which now allows me access to MAX or high res.
Another happy customer. If you have any favourite tracks/albums configured in Naim, I suggest you might want to see if there is a Max version that you can replace your saved favourite with
