Hi,
I don’t often use the DAB/FM module on my ND5-XS but I thought I would listen to Scala Radio today. It’s a relatively new station so, when it didn’t show up in the stations list, I did a rescan.
Now only three stations will show: talkSPORT2, Virgin and TalkRadio, although the re-scan says that 54 stations have been found. FM stations work without problem. I have an external ariel. The streamer is running firmware 4.7
Does anyone have any suggestions please?
You need to do a factory reset of the ND5 XS and that will give you all your zdAB stations back again…
Best
Thanks David. Absolutely right. All up and running now. I’ve also discovered that the neighbours have almost severed the aerial cable, but your solution worked.
