Can somebody fix this? Works on other platforms but not on naim vtuner
You will need to raise a ticket with Naim support.
So how do I do that? Is there a link somewhere?
I have also done it
As a workaround and quick fix there is also a possibility to add this station manually to vTuner (like I did). The problem usually is to get the correct URL but in this case @Paul_C kindly was able to provide that.
Not easy on muso qb2 - thereās no way to discover the vTuner mac address
vTuner mac address? You mean the mac address of the Naim unit (e.g. the muso)?
Try this: Muso qb2 - MAC address or IP address
On the vTuner login page, it asks for vTuner mac address. So the actually mean the device mac address? Is it also necessary to have a vtuner account?
Itās a nice station, thanks for the tip.
No ads, listener supported - excellent playlist. What more could anyone want (apart from a working vtuner streamš)?
It means the device mac address :-). Only just noticed now that it does in fact say āvTuner Mac Addressā. A bit confusing I think. You do have to create an account.
Thanks for the help
As I understand it there is a new software release, and once loaded Misty should work. Hopefully that will avoid signing up to vtuner.
New release? How will this be done - firmware updates or app update?
Itās firmware. Not sure of exact timing.
Since update Misty Radio now works
Didnāt prior to update
