I’m a newbie in this forum and have a question regarding an upgrade of my current system.
My setup is Olive 72/HiCap/140. I’m thinking about a bigger amp and replacing the NAP140 with a NAP250. But I’m uncertain if it should be an Olive or a Chrome Bumper. Does anyone has experience with a mixed setup like this. Or can you explain what the difference would be? My current setup sounds really nice but sometimes I miss a little bit more punch. For some music like e.g rock the sound could also be a bit warmer and less bright.
There’s no reason why you shouldn’t mix and match between the ‘chrome bumper’ and ‘olive’ styles, other than aesthetics. Also bear in mind that older Naim equipment will need to be serviced, if it hasn’t been through this in the last seven to ten years.
Personally, I would find it difficult to keep the different styles in a system that I would be looking at every day, but that’s a decision for you.
Sonically, the older Naim equipment tended to sound drier, or leaner, but you will need to listen to what sounds best for you.
Yes. I have a 250 which was made & bought as a CB (in 1985) - but was converted to Olive, by Naim (in 2003). Internally it is still a CB unit - albeit regularly serviced. Now used with an 82 (which is clearly Olive). Works very well.
I ran an 72/HC/250 for years, all olive, it was one of the better plateaus in my Naim journey. The SN1 I went to after was quite a let down. I think a chrome 250 will work fine if you can be assured it’s been recently serviced. But I’d go with an olive 250 if it were me.
I’ve played around with a lot of vintage Naim amps snd you wont find better synergy than 72/HC/250. You shouldnt lose money on a CB250 so just get that now and take your time to find a nice matching olive one. Make sure you compare first though nefore letting the CB one go.
250 is more refned and controlled than 140 so should do what you want.
