Mu-so 1st gen stubbornly stuck in -2hr local time
After a reset, my 1st gen Mu-so is stuck in -2hr my local time (Spain), so (as I learned today by being late) alarm works with a 2hr gap. Is there any way to change this?
FYI, my router is set to local Spanish time
Go into settings and select another timezone and then go into settings again and this time select the correct timezone.
Thanks David,
You mean the settings of the router? I did that and the issue persists
No, settings for the muso in the Naim app. Or actually I think the muso takes the time from your phone, so change the time zone twice in your phone.
Thanks again David
I tried chasing time zones in my iPhone and didn’t work. I don’t find any way in the Mu-so app to change the time settings (it’s a 1st gen). It seems the Mu-so gets the time from somewhere, but can’t find the way to set the correct time
I can’t see anything on my gen 1 muso Qb either (turned on after several months of not being on just for this!).
It will be getting the time from the internet then. Maybe try another factory reset of the muso.
Perhaps someone else will come along with another idea.
It must be from the internet; I’ve just overridden my phone time:
