I just bought two new Mu-so 2nd instead of the old first generation ones. Even for an ear that is not too sensitive like mine, the difference in audio quality is certainly evident, so I am very happy.
I wanted to ask one thing: I saw that the case seen against the light has imperfections, something like stains. It’s a normal thing?
Did I only notice it?
Thanks Tony, I’m not sure I can see it terribly well in the photos. Maybe show it to your dealer and see what they think? It may be easier for them to see.
Have you tried cleaning the offending areas, I found on the muso fingers prints or other residue, worth a try with something gentle or what the manual suggests.
