Hi All. I searched this topic but couldn’t find anything. I have a MuSo 2nd gen. I only use the app and not the touch panel on the top. Lately my cat has taken to walking on the dresser where it is located and turning it on, usually in the middle of the night! Is there a way to deactivate/turn off the touch sensor on the top so it doesn’t activate with the cat being near/on it?
If you still have the packaging that the Muso came in there should be a transparent plastic disk that covered the touch screen. You could try placing that over the screen at night.
You can also try pausing playback before turning it off.
I now do this as sometimes “someone” has been known to accidentally turn it on (and thus the music) when walking past or looking for something…
Thanks for the quick responses. I really appreciate them. I think I will try a “hybrid” approach of maybe covering the top with something and trying to remember to pause the playback instead of just stopping it by going into Standby.
Naim discontinued cleaning mode, apparently because feedback was that people didn’t bother with it.
There were occasional posts here from people thinking their Muso was bricked having accidentally turned it on, so perhaps they took a view that it caused more trouble than it was worth.
Which is rather silly all in all….From memory of my gen1 mu-so, it wasn’t so ‘accidental’ to turn on Cleaning Mode, you had to actively do it via the App….
If you think you’ve bricked your mu-so and forgot you had meddled with cleaning mode, then you perhaps are fit for the Darwin’s Awards……!
I would not blame the cat. I have two musos and several times they have both switched themselves on unexpectedly. Didn’t happen before the fw update. I have a suspicion that it reacts to an internet drop out.
I turn the volume down when done listening.
There is a very simple solution, order a bespoke perspex cover.
The issue was raised here on the forum for tts and rcm.
The suggestion assumes the manufacturers can bespoke an inverted ‘u’ design, so that when placed over the Muso, the top and sides are perspex and the front and rear are open.
Since the idea has been offered before, the very first item in search brings up this thread, there may have been others.
ps my Muso2 has never come to life unprompted, ditto Qb2, which I recently moved on when an opportunity arose, in anticipation eventually, of a Qb3.
There is a lot to consider with the plastic cover. What dimensions? Cost? How high does it need to be? Will it actually work? Has anyone done this successfully? Will it look ugly and spoil the nice aesthetics of the Naim unit?
It’s just too much to consider tbh. I wouldn’t describe it as a simple solution.
