I bought an extra grille for my Mu-so 2nd Generation and I doubt which side is up, since the grille fits both ways. From pictures on official web site, it shows that the bumped part is up but from inside the grille, I see a fitting concave part. Does anyone know which side is correct?
Got the peacock version on mine. The “bumped” part is right/up seen from outside.
From inside you got a small marking (round, small) that goes on the left side.
Thanks for the reply. For me, the round bump inside is at left side of the device but looking at it, it is on the right, obviously
I will add the pic here.
I think you have to move it 180°… it is on the wrong orientation.
Here is mine, position is like the factory delivered one (the grey grille).
Ok then. Thanks.
This is such an addiction, especially after starting working from home, spend more time in etc. I get obsessive and obsessive and obsessive about the subtle things… Subtle Mu-so things
That’s peacock right? Looks really great. Does anybody know whether these Mark2 grilles also fit on the Mark1? In my case the Muso-QB, not the Muso. Mine is currently fitted with that Blue/Greenish one, I’d swap it right away for this if I could
Qb grilles v1 and v2 are interchangeable.
QED. Just got the shipment in. Much better having that subtle black speckle…
