Angel, I guess what you propose is possible. The main issue will be in getting the volume level right for the Mu-So when in “centre channel” use. There will always be a bit of juggling there and it will never be exactly the same each time.
Also, forget using Bluetooth as a permanent solution. BT is there for convenience only, it’s not a patch on s/pdif or even the analogue AUX in performance-wise, and BT is notoriously flaky at times if not in perfect line of sight.
p.s. I’ve moved this thread to the Home Theatre room, as is appropriate.
Do you mean the original Muso, or the recently released Muso 2? The latter has an HDMI ARC input, which would be your best bet for connecting to a TV. (Assuming your TV has an HDMI ARC output.) Otherwise, just use optical.
It’s still playing stereo, i.e. you get the stereo once with “limited width” in the center and “full width” from your normal speakers. Unless you could tell the Muso to run a mono-mode (from the stereo input)?
You won’t get the benefit of the “central channel”, like voice mixed there for better “clarity”. Just more of the same stereo signal. (And if you have a Nova, I doubt the Muso will either add quality, clarity or “oomph” to the mix?)
Would be a good test, how “latency free” the multi-room setup is.
It’s a nice experiment though - but I would only do it, if the comports are readily available without any investment and hassle.
Thinking of this:
Maybe Naim can build a streaming-source, which takes in 5.1 sound (none of the new streaming platform can do it) and send it via “multi-room” to different Naim comports for a 5.1 setup?
(Would be a chance to sell many of the boxes… Nova for main channel, Muso for center, 2 Qb or 1 Atom for rear… and where to connect the Sub? )
I mean. that’s what others (Sonos, Yamaha, …) do with their components (at least selected ones).
But likely it’s easier to get a real A/V-Receiver…
Yes, I had had the similar thought earlier, if Apple could do that via Airplay (2) from an Apple TV and using different target systems for the different channels from 5.1/7.1/whatnot input.
But I guess it would be very hard to get a “rounded and precise” system in this way, like getting a proper A/V Receiver and a matching set of boxes.
