Mu-So Gen 1 Wifi discovery issue
Since a couple of app upgrades, my Muso-Qb (gen1) can’t be discovered anymore on my iPhone when it’s using wireless. When plugging-in the ethernet cable, the Muso appears on the app.
I’ll never ever invest 1€ in this shitty company!
Yeah, Apple is rubbish!
I thought the conversation was about buying products not investing in the company?
If you are talking about Apple, I’ve done great. I invested $6K ca. 2010 and have done really well. It’s paid for my Dynaudio Confidence C2 Platinum speakers, a Mu-so2, a custom-built Moots titanium road bicycle, a 300DR, 2nd hand 252 and something else I forgot about. And it’s still worth almost $30K now. If I had never touched it the position would be worth well north of $100K.
The cool part is that original $6K was free money. It was from a former employer contribution to an IRA that I rolled over when I left.
If you buy a product from a company, you invest in the company, or what do you think happens with your money?? Ever heard about margin etc?
Investment is different in my book, but no matter, your experience clearly has pug you off Naim.
How so? Investing in a company means some kind of financial or resources input into the company in exchange for financial gain. Buying a product from a company is not investing in the company as there is no financial gain to you associated with the purchase, only a loss of the purchase price. You haven’t invested in Naim, you just bought one of their products. And you didn’t buy it from Naim because they don’t sell to the public.
Tbh, my software experience with Naim has never been good. The App exists already so many years and is still not stable. At some point, dropping suppport in the app for some device is not done. My almost 20y SONOS is still supported in their app.
It’s not about investing or not, the point is about paying for something for which they all of sudden decide to drop support.
That’s what you said, not me. Anyway I agree that it’s frustrating.
What device are you talking about here? If it’s the Gen 1 Mu-So then it’s still supported by Naim and should work with the current Focal & Naim App. If you are experiencing issues then probably best to start a separate thread in the appropriate Streaming Audio room.
My Muso QB Gen 1 is playing fine as I sit here - connected through the updated app on my iPhone. When I first had the Muso I did have some connection problems but they were caused by the configuration of my wifi set up at home.
I also have a Gen1 Mu-So.
After a software upgrade, my Apple iPad couldn’t “see” the Mu-So. I contacted Naim and they suggest a solution. Can’t remember what it was exactly but it was very quick and easy to do. Worked properly since then
As per my previous post, I’ve created a new topic for you
Mirrors my experience too.
I’ve owned Muso 1 and Qb1, both had to be setup in app several times as they sort of disappear.
Really frustrating as I’m a complete novice in this streamer world.
I finally ended up selling them, bought a Sonos for kitchen and Atom upstairs.
My Atom does it sometimes too unfortunately.:thinking: :man_shrugging:
TBH I have no idea if its my router specs or Naim app to blame - I just want it to work.
I think a lot of people probably feel as you do. I certainly did when I first got involved with streaming, and it was a very steep learning curve. Fortunately I’m technically minded so I was able to grasp at least the essentials of it fairly quickly, but it wasn’t easy and required lots of reading around on line. One of the issues I think is that manufacturers seem to assume a certain level of IT knowledge and ability on the part of users. I don’t know your age group, but in my case, in my mid 60’s, I’m probably a lot less familar with this stuff than the average teenager, to whom it is largely second nature and part of their education.
I’ve now abandoned streaming and we’re back to good old CD. So much easier and simpler. A weight off my mind and it sounds better as well.
It’s a gen 1 Muso-QB. It doesn’t show up in the app anymore from one App version to another. So, nothing to do with the Muso itself.
I did a factory reset etc already a couple of times. Nothing helps. The only way to get it (back) on the network is to put an ethernet cable in it. Than, I can add it to the network. I can even specify it needs to go over wilress.
When disconnecting the cable, the Muso plays, but doesn’t show up in the app anymore. Quite frustrating, as I’ve to live with the 5 presets.
And yes, I’ve tested this on multiple Apple devices, having different iOS version, and also on an Adroid device. All same behavior.
When you try to add the device via a Wireless connection, the discovery in the set-up takes ages, saying at some point it failed.
Doing the same exercise with an Erthernet cable plugged in goes flawless.
Your problem isn’t the Naim app. It’s the WiFi performance of your network at the location of your Muso.
The Naim App can’t see a device that has dropped off your WiFi network. You can check that by logging into your router and seeing whether it is seeing your muso.
The muso WiFi performance was never brilliant and connecting by Ethernet is a far better strategy. Having said that, my gen 1 muso Qb is connected by WiFi to my network and it’s always visible in the app.
Have you got different IP address ranges for Wifi and wired ethernet at home?
