the Alarms have vanished from the App for the MU-SO QB 2nd Generation.
Any of you experiencing the same problem after the latest App- / Firmware Updates?
I’ve just checked a couple of mine, just updated them all this morning…
And seems to be the same as what you have: Mu-so has the alarms in settings, the Qb does not…!
I don’t tend to look at the Qb much in the App as I typically multi-room to it from other devices, so I would probably have never noticed….
Having said that, have never really used the alarms function anyway….
Guess it’s either an oversight in the new firmware or it’s been removed for some reason….Hopefully @Stevesky can confirm…?
I have the same issue. Two QB2’s updated yesterday and now the alarm functionality has disappeared. The alarm worked this morning but obviously lost the ability to change the settings.
It‘s not related to the Mu-So Firmware update rather than the Naim App version on IOS .
With an older iPad (app 7.0.1) the Alarm can be set as usual, with a new iPhone and IOS App version 7.1 the Alarm is missing.
It’s been reported by at least one poster above. I’d imagine Naim will see it as high priority as it’s a feature completely missing. (This is just my personal view with no inside knowledge.)
An old Qb is also fine.
So it’s looks like a combined problem iOS 17.6.1, Naim App 7.1 (11739) with the MuSo QB 2. and only the QB 2.
But this is not my only problem. Showing to my favourite web radio station is an triangle with a „!“. Telling me that the link to this radio station will expire soon. And it is telling me, that I should do something. Saying I should save it again. But it doesn’t show where and what, because the sentence beaks of (see screenshot). If I try to take the „favourite“ of this station, it tells me, it is connected to an alarm, and I should disconnect it before.
So I can use the alarms and I can’t renew my connection to my favourite web radio station.
That’s pretty bizarre. I hope someone of Naim is reading here and fixes things soon.
We just realised, that our son got the Naim App 7.0.1 (11293) with an iOS 18 something. There we’d been able to do the alarm settings we need for tomorrow.
