Listening to RMF CLASSIC (Polish radio) it was an issue.
Now I’m streaming Naim Radio and seems to be fine…
Any steps I should take to maybe solve the issue with Radio Broadcaster? What I shall I say them so they are aware what to fix?
Hi Artur,
It’s usually a technical issue re the stream, which may then cause issues with the radio platform we use (vTuner). Again, not my area of expertise - i know @Stevesky is insanely busy, but sure he’ll see this.
I have been playing RMF Classic here without any issues on Mu-so Gen 1 and same fw versions as you.
Can you confirm if you still have a problem listening to RMF Classic this morning?
When you have Internet radio streaming issues it is best to check out the stream on vTuner using a web browser to see if you find the same issue. I have no trouble with RMF Classic stream: vTuner Internet Radio
Can you stream the station from its web site via a tablet?
I had something similar recently where the app variously couldn’t find the streamer or if it could it was never ready, but airplay still worked.
QB2 in my case.
