The Mu-so Qobuz update has been released, but I am unable to download it. When I check for updates, the software says my Firmware is up to date.
Kind regards,
Simon
Kind regards,
Simon
If in check for updates it says version 6174, then it is up to date. If not try unplugging the unit for a minute or so and then recheck the updates section of the app after 5 minutes or so?
Hello Gazza,
Many thanks for your quick response. I followed your instructions, but still no luck. My Firmware version is 4.1.3 (5573)
Kind regards,
Simon
I suspect it’s bring rolled out region by region rather than everywhere in one hit.
Thanks, Robert, makes sense.
This morning my NDX2 was telling me that the update was available, but my Atom was not. Going to Settings > Check for Updates, it was avaliable though. I dare say yours will show it sooner or later.
Now fully working. A great update, thank you Naim and Qobuz.
