Is it possible to stream from say my phone or my desktop to the mu so?
Both Bluetooth and Airplay will work.
Also chromecast if you have android.
If you have Spotify then you can use Spotify Connect which is even better (and Tidal Connect allegedly on its way)
The short answer is yes. The long answer is yes, it isn’t too difficult, follow the steps on the Naim online manual.
