It gives āif Darth Vader was sort of into HIFIā vibes.
But no analogue in or phono in.
So not the case if you use a turntable, cd player with no digital out, tuner or reel to reel.
Presumably this is a typo.
A sub would be analogue out.
It might be useful to understand a bit more about how exactly the Naim branded Utopia differs from the (cheaper) Focal branded Hekla given that they have so many similarities. Presumably the Utopia is more focused on Audio and the Hekla on AV use, but it seems that both products can handle music and AV with a similar range of inputs. Perhaps @Paul.B could explain?
Iām very confused ā¦
Arenāt we allā¦ā¦ā¦
Still struggling to identify exactly what are the differences between the Utopia and Hekla, others than 720w up from 660w?
ATB, J
Itās a Naim product release so expect the usual errors and omissions ![]()
After a lot of cutting and pasting, the following are from their PDF Specs
| HELKA | UTOPIA | |
| Speaker Drivers | 15 Speaker Drivers Front: 3 x Woofers (6āx3ā) 2 x Midranges (2.75ā) 2 x Tweeters (1ā) Side: 4 x Full range (1.5āx 2.75ā) Top: 4 x Full range (1.5āx 2.75ā) |
15 Speaker Drivers Front: 3 x Woofers (6āx3ā) 2 x Midranges (2.75ā) with āWā speaker driver āMā-shaped 2 x Tweeters (1ā) with PRISM technology Side: 4 x Full range (1.5āx 2.75ā) Top: 4 x Full range (1.5āx 2.75ā) |
| Bandwidth (+/-3dB) | 30Hz ā 20kHz | 30Hz ā 20kHz |
| Low-frequency cut-off (-6dB) | 27Hz | 25Hz |
| Maximum sound level | 108 dB SPL (@1m) | 109 dB SPL (@1m) |
| Amplification power per speaker driver | 660W on 15 speaker drivers Woofer: 3 x 60W (4Ī, 1% THD) Full range / Midrange / Tweeter: 12 x 40W (6Ī, 1% THD) |
720W on 15 speaker drivers Woofer: 3x84W (4Ī©, 1% THD) / Full range: 8x42W (6Ī©, 1% THD) / Midrange: 2x42W (6Ī©, 1% THD) / Tweeter: 2x24W (at 8Ī©, 1% THD) |
| Analogue output | 1 x RCA pair for subwoofer connection | 1 x RCA pair for subwoofer connection |
| Digital inputs | 1 x Optical TOSLINK (up to 24bits/96kHz) 1 x HDMI eARC, CEC 1 x RJ45 Ethernet |
| Streaming services | TIDALĀ® QobuzĀ® QQ MusicĀ® |
| Wireless streaming technologies | Google Cast AirPlay Bluetooth® UPnP⢠Spotify® via Spotify Connect TIDAL® via TIDAL Connect Qobuz® via Qobuz Connect QQ Music® via QPlay (China only) |
Google Cast AirPlay Bluetooth® UPnP⢠Spotify® via Spotify Connect TIDAL® via TIDAL Connect Qobuz® via Qobuz Connect QQ Music® via QPlay (China only) Presto Music via Presto Music Integration |
| Internet Radio | Internet Radio (with Xperi extended Metadata) from Naim server Streaming containers: HLS, DASH, OGG. Codecs: MP3, AAC, Vorbis, FLAC, OPUS. |
| Audio Format | WAV ā up to 32bits/384kHz FLAC and AIFF ā up to 24bits/384kHz ALAC (Apple Lossless Audio Codec) ā up to 24bits/384kHz MP3 ā up to 48kHz/320kbits (16bits) AAC ā up to 48kHz/576kbits (16bits) OGG ā up to 48kHz (16bits) OPUS ā up to 48kHz (16bits) DSD64 and DSD128 BluetoothĀ® 5.1 ā SBC, AAC Note: handles smooth, gapless playback on all formats. All formats to 384kHz maximum over wireless network. |
| Multichannel Audio Format | -Dolby Digital AC3 Channel based 5.1 up to 48kHz -Dolby Digital AC4 Up to 7.1.2 up to 48kHz -Dolby Digital Plus (EAC3) Channel based: 7.1 up to 48kHz; Object based 16ch up to 48kHz -Dolby Digital TrueHD Channel based, 7.1 up to 96kHz; Channel based 5.1, 192kHz; Object based. 16ch up to 96kHz -Dolby MAT (HDMI only) Channel based: 7.1 up-to 48kHz; Object based 16ch up-to 48kHz -Multichannel FLAC (Streamer only) Channel based 7.1 up-to 192kHz -Multichannel WAV (Streamer only) Channel based 7.1 up-to 192kHz -Apple APAC (Streamer only) Configured to 7.1.2 mode up-to 192kHz |
| Multiroom Connectivity | Sync up to 32 Focal & Naim streaming devices and control them from the | Sync up to 32 Focal & Naim streaming devices and control them from the Focal & Naim App |
| Network | Ethernet (10/100/1000Mbps), Wi-Fi 6 (802.11 a/b/g/n/ac/ax) | Ethernet (10/100/1000Mbps), Wi-Fi 6 (802.11 a/b/g/n/ac/ax) |
| Automatic Standby time | User selectable: adjustable from off up to 2 hours (default Auto Standby: 20 minutes) |
| Rated power consumption | 200W | 220W |
| Power consumption in network standby mode | < 2W | < 2W |
| Power consumption in standby mode | < 0,5W | < 0,5W |
| Main power supply | 100V to 240V, 50/60Hz | 100V to 240V, 50/60Hz |
| Dimensions (HxWxD) | 4.65x39.37x11.61ā (11.8x100x29.5cm) | 4.65x39.37x11.61ā (11.8x100x29.5cm) |
| Weight | 15.5 kg | 14.1kg |
Many thanks for the detailed comparison.
And, of course, the red stripeā¦ā¦
ATB, J
I gather from the articles itās only available in Focal Powered By Naim (FPBN) stores. I really struggle to see the strategy there. I live in North London, my nearest dealer (Grahamās) is a very early Naim dealer, Iām fairly sure they carried Naim in the ā80s, and stock up to the 500 series. Within a few miles is another 500 series dealer (who also carry Focal). According to the Naim website my nearest FPBN dealer is in Kent 47 miles away as the crow flies. (I must admit I thought KJ W1 were, but not listed.) so if I wanted to demo this I have to travel all the way to a dealer I donāt normally use ignoring my local Naim specialist.
I struggle to see how this brings them additional custom.
This may be temporary?
I checked the German F&N distribution and it seems the Hekla is now āavailableā which was also āexclusiveā initially.
Just guessing, though.
But using Mu-so for a Focal product and now Utopia for a Naim product (both sharing seemingly chassis, speaker layout and electronics/software) - are they gonna give up having separate product lines / brands and blend/merge them?
And just the one hdmi again! I just donāt get it. I want a selection of hdmis to plug all sources into for the sound quality and then pass-through to the tv.
Will we see a Uniti Utopia next?
Together with a pair of new āQbsā as rear speakers connected wirelessly.
Modern lifestyle says: you connect everything to the TV and eARC to the audio device.
Saves the audio device from having to pass through 4K/8K video streams with new codecs, bandwidths, HDR, and HDMI versions every few years. So thereās actually a reasonable reason to do it that way around.
Modern lifestyle is people listening via their phones, etc over bluetooth. This isnāt modern lifestyle, itās a Ā£4,500 sound system, from a company 99.9% people havenāt heard of.
Perhaps the Utopia should have been called.
Helka Heavy ![]()
Except that itās actually lighter
ATB, J
I have wondered if thatās a misprint - surely more power equals more weight typically
