The new Gen 2 Mu-So arrived today and it’s hung up ‘getting Wi-Fi ready’. It’s slotted in place of a Gen 1 which has been used with a wireless connection. It’s within a couple of feet of my router. Also, my apartment has strong, unprotected Wi-Fi. Other than getting started using the pin hole, there is nothing I can do. I’ve waited for several hours.
I"m trying to go through Naim’s setup where they start with Wi-Fi. I’m going to unplug it and start over. If that doesn’t work I’ll connect it to the router and see how far I can get with it.
The V2 Mu-So is slotted into the spot my V1 Mu-So was sitting and it worked perfectly on Wi-Fi.
I just replaced my Nova with a new NDX 2/SN2, both with added power supplies. I just bought the Mu-So because I can use it with my TV and it supports Roon, etc.
Well, I found an Ethernet cable long enough to connect it to my router. Everything works perfectly. It sounds great. What my NDX 2 can do the Gen 2 Mu-So can do.
In the days when an Ansuz power cable can list for $40K, the Gen 2 Mu-So is an absolute steal.
Once a device works with a wired connection, it may continue to work if you revert to WiFi if that’s your preference. I would keep the cable if you can, though.
