Hi All,
I have a MU-zo 2, has anyone managed to use their MacBooks to control their streamer?
I can’t seem to work it out. I’m using Tidal.
Thanks for any advice/help
Hi All,
Regrettably you cannot control a Mu-so from a MacBook.
There was an app you could get, called QuteControl that enabled some basic operation but this is no longer available.
IOS and Android are the only options.
Find the IP address of your Muso, and type it into a browser with /webclient on the end. With the other current generation streamers, this gives you a basic version of the Naim app, so I’m guessing it might work for the new Musos too.
