I’m doing a multi Room with a Mu-so 2 and a QB 2. They’re not in synchrony. Seems internet radio plays the best. Qobuz and Tidal don’t work as well. Any fixes out there?
Multi-room works perfectly for me.
May I ask how you start the multi-room?
Might it be possible that you’re accidentally not using multi-room?
From the now playing screen, the four small squares should be touched, then select the Muso you wish to join the multi-room.
Apologies if this is what you’re doing.
So, thanks for getting back with me. Curious, are your two units in the same room or separate? There’s definitely a millisecond delay between the two Mu-so. My Mu-so 2 & QB2 are in one room. When positioned between the two units these’s definitely a delay. The room they’re in is a large downstairs area, no walls, very high ceilings. One Mu-so was not enough, a second unit was necessary to balance out he sound so you get direct sound wherever you stand in the room. Tell me what you think, thanks in advance.
Mine are in seperate rooms although my main NDX2 is in the sitting room which is effectively open-plan to the kitchen where I have a QB1 and cannot notice any delay.
Maybe because they’re about 40 feet apart I don’t notice?
I’ve seen this a few times as well. AFAICT it always starts out synchronously, but can get out of sync when there are dropouts. Perhaps when the buffer runs out?
The WiFi implementation of these devices is pretty bad unfortunately.
Dont know much about this feature, but do you get the same issue if you place the debones next to each other?
Are they both connected via WiFi?
Is your router near by?
Have you tried removing the power from each, then power them up next to each other, with a minute apart.
Ultimately you could also try and remove power from your router for a minute, to ensure it flushes all its caches?
