Hi there,
New poster and looking for some help advice. I have two 1g Mu-so and 1 1g which I play depending on where I am in the house. I usually control the Mu-so using Spotify connect … I would love to multiroom set as default . At the moment in use Spotify to start listening and then I need to log into the Naim app to enable multiroom which is a bit clumsy.
Does anyone know if/how this can be done ?
Many thanks
