Multiroom via Digital inputs?
Hi all,
I have a Naim Uniti Atom HE Edition.
I want to listen to some music i have on Youtube.
I connect my Samsung Frame TV to my Uniti HE Edition via Digital Input 2.
When i go to the app and try to play multiplay to mu QB and/or Muso it wont connect to them?
Is multiroom an option via Digital 2 input?
And if this is not possible how do i connect the Naim Uniti Atom HE Edition to the Samsung Frame TV via wifi? Which im assumming would then enable multiroom?
Multi-room is possible. I have done it from my TV to my old SuperUniti over digital connection and later, into my NDX2 which would indeed play multi-room to my Muso-QB.
I don’t believe there is a way to do it using only wifi.
Multiroom works over WiFi or wired Ethernet. The only limitation is that your network may struggle to handle multiple multiroom connections over WiFi so keeping as much of the setup wired as possible will always be preferable.
Connecting non-Naim devices is another matter, as they can’t use Naim miltiroom.
Would something like WISA solve my issue? ie will it let me play music from my TV in high quality over my Muso speakers?
