Naim app needs to have some development - actually it probably would be easier to start from different angle over than try to fix old one… I’m sorry, but this is my opinion.
Is there other way to control these Mu-So’s with multiroom function?
No there isn’t.
The app works well. I suggest you should have another look at it!
Best
You can, depending on which generation of Musos you have, use AirPlay, Chromecast or Roon to play in multiroom mode. Personally I find the Naim app as good a way as any.
