Hi, I use my muso as a soundbar and when it has a good day also plying music (multiroom).
Is there possibility to set sound volume separately to digital output… every time when music begings whole building hears that… Can’t fix that from tv.
If you go to the settings menu in the Naim app, under Input Settings, open the Digital input and you should see ‘input trim’. You can use this to increase or decrease the relative volume level of that input. (I’m assuming the Muso has this option, as the 2nd generation models do, as well as the other Naim streamers.)
