Hi All
I had wifi router running 2.4 GHz and 5Ghz networks on different SSIDS. However I was not able to initialize the box using 5g network but was OK to do that using 2.4 Ghz Network. However when any of my iphones got connected to 5G network appliance just disappeared from the application.
To troubleshoot the issue I did the following
- Initialized the box using 2.4 Ghz network
- Manually connected the box to 5G using http://ip_address/naim/index.fcgi
- tried to connect Naim app to the box while Iphone being connected to 5G - no result
- disabled 2.4G on the wifi router and tried to connect Naim app to the box while Iphone being connected to 5G - success.
Probably the box itself is not able to work correctly with wifi dualband wifi routers even with different SSIDs for each of the network
