Hi,
I want to replace my iMac with a new iMac 27”. It’s bigger and I can’t use my Audio Engine speakers anymore.
I would like to buy a Muso 2 and use it as a computer speaker but then I will have to put the iMac on top of the Muso 2.
Is it possible?
Considering heating, weight (iMac is 9kg)?
I nearly went down this route myself - but went for KEF LSX instead - partly because I felt that the ergonomics of a 27" iMac on top of the Muso would make the iMac just a bit too high for comfort. But this is a personal thing etc.
My gut feeling is that the sound from the Muso might be a bit much being so close to you. It may be ‘only’ a soundbar, but it does pump out the sound in a way that some people find a bit relentless, especially if close to a wall.
Also, I’m not quite sure you would be able to put the iMac centrally on top without touching the control wheel. A stand like the one in Gavin’s post might get around this, as long as it doesn’t raise the screen too high.
