I have connected my MuSo to my TV using HDMI ARC. It works fine watching stuff on YouTube but when I try and watch Netflix or other channels I just get a buzz and no sound.
It isn’t a connection problem because YouTube works fine.
They are probably sending a multichannel bitstream signal to the Mu-So. You need to set the TV to PCM 2 channel. The Mu-So uses a 2 channel DAC so can only decode a 2 channel digital signal.
Perfect. Took some time to find the setting but worked a treat.
Thanks Richard.
