Is there a way to have the Muso always default to the Device page
I have several Muso’s around the house and currently it always returns to the last unit that was playing. this is not always convenient. As soon as the app “sees” that device it turns it on (I might not be in that room) so I have to power it off with the app and then when that devices turns off, it returns to the device page
I would like this too.
Click on the device name at the top, the app returns to the “rooms” page.
Hi Robert, thank you for the response, but this doesn’t solve the problem of the incorrect room having been powered on. I appears the only way to solve this is having an option to default start up to the Rooms Page, not last device played as it does now… Thoughts on a firmware fix? ![]()
That’s more likely to be an app change to add a startup screen preference; options between last used device and the rooms list.
I suggest sending a suggestion to support@naimaudio.com.
