How do I switch the WiFi connection.?
Does it require a device reset?
Are you using a PC or tablet?
Can’t get past extermal inputs… Using android tablet
Ìm using iPad.
With my phone it looks like this
There is a small button to scroll down.
It’s a bit tricky
I’ll give it another try
Finally managed to get to settings and network. Messing this way looks ‘dangerous’ to me . Looks too easy to mess things up.
I guess the other way would be a reset and setup as ‘new’ device.
